Interchange assembly question - component interface
  • April 20, 2012
  • 2 replies
  • 1267 views
A question for the interchange assembly gurus.
Sometimes our customers will request LED lights instead of the default
incandescent on our trailers. To facilitate this, we have a Component
Interface in both the LED light and the original to speed up assembly - both
models simply assemble to a coordinate system origin in the mounting
grommet. I thought it would be nice to further speed this up by relating
the two models with an Interchange Assembly. It's been years since I've
used these, so I'm hoping you all can help me figure out what I'm doing
wrong.
I added the two lights to my interchange assembly and added a reference tag
for the coordinate system origins. So far, so good.
When I went to swap out the light in the trailer, I got the following error
message:
"Component Interface missing, continuing placement will cause interface to
be removed. Yes/No"
So I choose yes, then the component assembly dashboard pops up, and it says
fully constrained, so all I have to do is MMB and it completes. So it's two
more mouse clicks per light. No big deal, but we have at least 13 lights
per trailer, so I'd like to eliminate that.
A little bit more background: the two lights are identical, except for
parameters - one was duplicated from the other, so they do both have the
same component interface, even and the names of the component interface are
the same. (I know, I know, we probably should have made them instances of a
family table, but here we are).
Am I missing a step that would allow me to eliminate this error message?
Thanks.
WF3, Intralink 3.4
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
6-Contributor
April 20, 2012
Lyle,
I believe this is caused when the original part was "placed using interface" instead of placed manually. If the part was placed manually you don't get the error. Please let me know if you get a good answer because we would like to know also.
Donald Pilkey
CAD Leader
Chris3
Say Donald stated below the message is because the first component has a
component interface (Insert -> Model Datum -> Component Interface) and
the second one doesn't. Add the same interface to the second component
and you will stop getting the message.
Chris
This communication, including any attachments, consists of non-public
information that is intended solely for use of the individual or entity
to which it is addressed. It is a confidential communication that may
contain information that is proprietary, privileged, export-controlled
and/or exempt from disclosure under applicable U.S. and non-U.S. law.
If the reader is not the intended recipient, or agent responsible for
delivering the message to the intended recipient, please notify the
sender immediately by reply e-mail and delete the communication,
including any attachments, from your system without saving any
information or making any physical copies. Unauthorized use,
dissemination, distribution or copying of this communication, including
any attachments, is strictly prohibited.
