Pro-E drawing (DRW) to AutoCAD drawings (DWG)
  • August 3, 2010
  • 5 replies
  • 3635 views
Is there any way to convert pro-e drawing to AutoCAD drawings (DWG
format). I am aware of the fact that we can convert using save a copy
option but it does one sheet at a time.
Is there a method to make entire file converted to DWG?
Thanks and regards,
Jnanesha KS
T 91-80-4119 0900 Ext: 233
F 91-80-41190901
M 994 500 4179
Quality Engineering and Software Technologies
No 55 l QuEST Towers l Mahadevapura l Whitefield Main Road
Bangalore l 560048 l www.quest-global.com
Jnanesha
Yes you can convert / save a multiple sheet ProE drawing to a multiple sheet AutoCad drawing ".DWG". While doing the save as process select the sheets tab and select the "All sheets as paper space" option.
Dave McClinton
MCAD System Administrator
McKesson Automation
724 741 7760
david.mcclinton@mckesson.com
This sounds to me like a SIMPLE dxf exchange. I don't understand where there
would be any problems. In almost every case you will find something that
does not translate perfectly from one CAD platform to another. Although I
have seen where going from Pro/E to AutoCAD is one of the least painful
experiences.
So do what you need to do and move on. Don't make it any harder than you
have to.
Michael P. Locascio
August 3, 2010
Only recent releases of Pro/E can export the entire drawing to AutoCAD..
For example, Wildfire 3 does not have this option.
See? It was an English problem, not a Pro/E or PTC problem.
Michael P. Locascio
http://portal.ptcuser.org/p/fo/st/topic=3&post=66868#p66868
In Reply to Jnanesha Kanti Subrahmanya:
Thanks and regards,
Jnanesha KS
F 91-80-41190901
M 994 500 4179
Bangalore l 560048 l www.quest-global.com http://www.quest-global.com
Michael R. Jenkins P.E.
Design Engineer
Direct: 816-801-2332
Fax: 816-891-9432
Commercial Vehicle Systems
Haldex Brake Products Corporation
10930 North Pomona Avenue
Kansas City, MO 64153-1215
