Prime 2 - select with double click bug
  • March 1, 2012
  • 2 replies
  • 2162 views
In v15 we can select a defined value in a math region by double click on it and input another value simply by type it.
In Prime 2, you have to click inside the math region, use Delete or Backspace to delete the value and, after that, to input the new value.
Is there any way to replace an old value in Prime the same way as is is in v15?
If not, when will see this bug fixed?
spaco1-VisitorAuthor
No one?
It's a different way of doing things, not a bug. We are changing the overtype behavior for Prime 3.0.
Mona
@ Mona
I have a question.
Prime 3 will have the same (sorry, ugly) ribbon+icons or it will be changed to a new good looking one, like it is in Office 2010?
I agree. It's slightly annoying. Only slightly though, because it doesn't stop me from doing anything. The missing features in Prime do stop me from doing things though, so IMHO PTC really needs to spend their time on implementing these features rather than worrying about minor interface issues.
