1:creo12不能检索pro_Library_dir所指定的库中的元件。这是creo12的一个BUG么?因为其它版本的creo是正常的。
2:能不能设置一个选项,可以让功能区按键提示“ALT”被释放出来,用于快捷键比如ALT+1,ALT+F等。功能区按键这个操作太繁琐,按键次数太多并不能起到“快捷”的作用。而且在使用这个功能时因为软件要加载出提示,还会让软件感觉卡顿。再者大多数人并不会用到这个功能,况且还有一个F10可以用来做这个事。为什么ALT与F10两个按键用来做同一个事情呢。还占用ALT这个使用率超高的按键。
建议设置一个选项让用户选择是否使用这个功能,选择不使用这个功能时ALT键可以用来设置快捷键。
Hi @XX_10707671
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
pro_library_dir works in Creo 12.0.4.0 for me. I have it directed to a folder in Windchill using the syntax "wtpub://<server name in the server manager>/Libraries/<library name>". Note that the name of the server in the Server Manager MUST match the name used in the path in pro_libary_dir. However, if you're using a local directory, the full path should be fine.
Your second point looks like it should be in a Creo Idea, so it can be considered for future implementation. Drop a link to it in the comments here, if you post one, so we can find it and vote on it.
