Hi @ZW_10422446
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Creo looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
OP translated to English.
I am using Creo Parametric Release 5.0 and Datecode5.0.0.0
How to duplicate a local segment of a curve in a part and make the end point that generates a duplicate curve coincide with the two coordinate points
Your request is a bit vague. Is this what you are trying to do?
References / chain details / options: Change each end to trim at reference and select the desired reference (point, plane, line, edge, surface, etc).
