Article - "When save a copy model file to STEP format file with a Chinese characters as file name in Creo Parametric, it prompts warning message: "Invalid Name. Check to ensure filename contains only legal characters."": https://www.ptc.com/en/support/article/CS364372
Hello @YV_7802312,
It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
