14 Ways To Create Curve
VladimirPalffy
Do you like to learn Surface modeling with Creo Parametric 4.0?
It is good time to start to learn How to create 2D and 3D curves or 14 Ways To Create "Curve"
  • Sketched Curve
  • 2D Curve created between points
  • 3D Curve created by points
  • Curve defined by points from CSYS
  • Curve conected to another Curves
  • Curve created on a surface edge
  • Projected Curve
  • Wraped Curve
  • Curve defined by Equation
  • Intersected Curve by curves
  • Intersected Curve by quilts
  • Copy edge from solid
  • Curve from Cross Section
  • Trace Curve defined by mechanism
Best Regards,
Vladimir
Best Regards,
Vladimir Palffy
Thank you, very systematic Smiley Happy
