2D Drawing
SC_10434201
2D Drawing
Dear Creo Team,
My Name is Santosh vishwakarma, I am the user of the Creo from last 15 years.
I would like to suggest for the improvement of the Drafting module.
1. I suggest if the drafting Text and dimension can be auto set as per the scale factor of the Page size, for example : if user has selcted A4 sheet then the Text and arrow size should be auto set to the desire visible criteria of drawing factor , it should Not be tiny or large visible,
Actually it needs all the time setting the text size and arrow size as well as extension line and gaps etc.
2. Also the hidden line issue have been seen in case of projection, User has to select and correct for each time. It should show automatic projection lines of the hidden as well.
3. Also the there is one facilitation is required for Drawing no generation in order to continuation if multtiple drawings of child parts are created for the particular Assembly. So that the drawing number can be in order to define no of drawings and drawing number codes to define drawing number identification for the particular Assembly or Product Designing.
By the way, you can bring all your ideas here: https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
note 1.] You can create template for every page size and set detail options related to page size.
Martin Hanák
StephenW
(To:SC_10434201)
Note 2:) you can set your default view display in the drawing setup file (or drawing template)  under model_display_for_new views
Not sure this is what you are referring too
