Greatings,
my chef come with an idea, that chmafers should be shown not perpendicular to chamfer surface, but "the linear" shape is correct. See following picture for better immagination:
Does exist some technique or config.pro oprions for setting this?
The only l will never do is: Adding chamfers dimmension manually
have found https://community.ptc.com/t5/Detailing-MBD-MBE/Chamfer-call-out-shown-dimension/m-p/371845#M3202 but it doesnt help ![]()
Have no idea why the chamfer format is a problem, but it is...
Thy in any advice
Regards
Hello @MartinHanak
thanks that you drove me to correct way. Final drw.dtl config settings are:
default_chamf_dim_configuration LINEAR
default_chamf_text_orientation PARALLEL_TO_AND_ABOVE_LEADER
default_chamfer_text DX45
Have a nice day in Přerov...
Regards
with my dtl file I can see this ...
You can open attached drawing created in CR2 M070.
Drawing configuration file contains following options:
default_chamf_dim_configuration LEADER
default_chamfer_text 45XD
Hello @MartinHanak
Regards
