3D Creo Parametric Annotations in Creo View "Load-In" State
Rigoberto13
Hi everyone. I have a Creo Parametric 2 model that I've annotated in 3D. I've set up several states in my model that show the different annotations. My issue is that in both Parametric and View it appears there is some hidden or "un-editable" loading state. In parametric I've been able to get around any issues but in View, when my model opens up in the freshly loaded state before I switch to my specific states, I see all of my annotations showing at the same time. My coworkers and our vendors will hopefully know to switch to the viewable states where everything is oriented correctly but the issue arises in the assembly of these parts. If I export a View file of an assembly of annotated parts, my assembly doesn't contain viewable states, but it contains all the annotations clustered on top of each other and the parts.
I'm unable to share pictures of the parts I work on but I may be able to throw some dummy parts into an ASM if it helps describe my issue.
Basically my question is this: Does anyone know how, or if it's possible, to edit this "load-in" state? I'd like to remove all annotations from this state if possible.
Similiarly, in Parametric, it would be nice if I could load the part in a predefined state so that other people don't have to activate a view, it simply loads to "View 1" for example.
Thanks in advance.
0 REPLIES 0
