Hello
Uding CREO4
I need to create a 3D Note to be "related" to a dimension (or tolerance, or other note).
In "3D Annotate" I don't find the command "Related to object" as in Drawing mode.
Is it possible ?
In the pic I'd like to attached the blue note to yellow dim.
Thanks in advance
Pierluigi
It is not possible in detailing (drawing), and I do not think this it is possible in 3D Annotate either.
You could always post a suggestion here (unless others know how to do this):
https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
No, there isn't a way to relate the 3D note to a 3D dimension in the model.
