Auto horizon locking: Keeping the horizon always horizontal when rotating the view, which is equivalent to keeping the direction of gravity always vertical
Imagine you're making a model in the real world, you want to walk around your model to check its form or structure from different angles. But just as you start walking around the model, something magic happened, the horizon of the whole world began to tilt randomly. You have to struggle to keep your balance while continuing to think and create your model.-----This is exactly what happens when there is no "Auto-horizon-locking" feature.
This should be a function as basic as breathing in the real world, arguably more basic than anything else.
All existing relevant functions (orient mode ) are far from "Auto-horizon-locking".They all require extra tedious and unintuitive steps.
PTC has created an excellent product. But we hope PTC will pay attention to this missing basic feature that can seriously impact the user experience, perhaps especially for expanding the market, as many of the existing users may be used to suffering from balancing.
We're not dreaming of magical features, we just want to create models without the extra distraction of worrying about our breathing all the time. Thanks.
Creo Parametric does not have a horizon lock. You can submit a product "idea" here https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
The only option that I have seen could be the re-orient window, where you can rotate based on horizontal/vertical/normal or any selected entity.
Go to the view tab, select the drop down arrow next to saved orientations, then select Reorient.
You can orient by reference (which is a select entity) or dynamic (which is horizontal, vertical, or normal to the screen)
I personally wouldn't care for a horizon lock. My parts are used in a 3-dimensional world and I need to see if there is a problem from any angle, but that is my opinion only. It is often some parts are used in multiple orientations within my assemblies and its not unusual or my assemblies to have a motion that carries them out of a horizon type context...but this is my experience. I have learned over the years on the community that there are a million users and a million different applications of the software.
PTC parametric 7.0
Use Shift + (Alt) + Arrow keys - available in Creo 9.0.
Thank you for your reply. But I don't get the relevance of this to the problem i described.
Well, never having used this "Auto-Locking" of which you speak, I can't say as if I'd find it better. I'm so used to what's current (Creo 4 - yup, we're way behind) after using Pro/E for 25+ years, it's just second nature. I DID prefer the older way of moving/spinning/scaling the viewpoint though. I DO have the config.pro setting that eliminates the "Spin Center" and thus the view spins about my picked point instead, and I much prefer that. Can't remember exactly what that setting was though, it might benefit you in addition to the "alt" method also listed for Creo 9.
Me, I'm waiting to see what fancy new name they pick for Creo next...
Config to turn of spin center:
spin_center_display no
Yeah, that sounds right, just didn't have the time to look it up. Thx!
Thank you for your reply. But the "tilt horizon" problem I described is not just showing or hiding the "Spin Center". It's not a display problem.
Thank you for your guidance. There is no doubt that I do not represent all. What you said by using “orient by reference” and choosing a Horizontal plane to rotate the view is close to what I mean by “horizon lock”. I just think that even if it's a "direction-independent" dumbbell, I still want the horizon of the environment that created it to be stable rather than spinning around. I appreciate your reply anyway. I will submit this product "idea"
the suggest button grayed out
I think that means you have to upgrade your level of access on PTC. You can go to https://www.ptc.com/en/support/ and then click on your name/avatar in the upper RH corner. Then either Manage my account or upgrade my account. I don't know remember exactly what is needed.
Thank you.
I guess I don't see the problem. Are you hoping for a software where the VIEWPOINT moves in relation to a stationary model then? I've never heard of the method you've described.
Thank you for your reply.Something like using “orient by reference” and choosing a Horizontal plane to rotate the view.But not exactly that one.
I would also reeaalllly appreciate this "horizon locking" or "keep vertical up" behavior/setting.
Every other modeling program has this:
> Solidworks "Rotate about scene floor"
> Inventor "Constrained Orbit"
> OnShape "Set default rotation behavior to constrained rotate" (or hold Alt while rotating)
> Sketchup, Revit, and Maya have this behavior as default (afaik)
I've been searching once a week in case there's an update, or someone figures something out.
For those of you still looking/waiting for "horizon lock," I found something that could be helpful. Most useful if you're going to spend some time inspecting/familiarizing with/presenting a model. It's not really worth it for small/short model manipulations.
I created a mapkey to enter Orient Mode in the Anchored setting (set to "AA"). This at least seems to give different manipulation control, and a reference (the anchored triangle), to model manipulation. Anchored mode does a little stutter every 90deg of rotation, which could be a little distracting but it's subtle enough.
I also set a keyboard shortcut to Orient Mode (Shift + A), which can be used to disable (or enable) Orient Mode. (So, the workflow is "AA", rotate model for a while, "Shift + A".)
You can't select any model geometry in Orient Mode. Not a solution, but potentially preferrable on ocassion. Give it a shot.
