I am attempting to include my custom component as a connector in the AFX library.
In the script tab file, I'm adding connector references for assembly.
When I try to assemble that connector and the connector references are in the hidden state, afx displays an error.
For example, if I refer to a plane from a connector for assembly and the plane is in the Hide state in the connector component, afx will fail to assemble it.
We are using Creo 8 and Creo 10.
We use MBD for parts and ensure that all datums are hidden for the Model_only tab.
Anyone know how to use connector references, even if they are hidden ? Your help is appriciated.
I guess that references are not hidden but suppressed. If this is the case then you cannot assemble component.
Thank you very much. My MBD system automatically suppressed these datums when I regenerated my assembly. I fixed it and it now works like a charm.
