AFX lite
gbon
AFX lite
Can someone knows where I can find information about AFX lite limitations ?
Perhaps someone knows what we can and can't do with it ?
4 REPLIES 4
JimBarrettSmith
(To:gbon)
If set the config option in Creo 2.0 AFX_Enable to yes or pre Creo 2.0 EFX_enable to yes you will be able to have a play with the software and investigate whether the lite version is valuable to your business.
Jim
JimBarrettSmith
(To:gbon)
Oops typo Creo 2.0 AFX_Enabled / EFX_enabled
neluyt1
(To:gbon)
EFX Lite has the full capability, you have access to all the joints, profiles, fasteners etc.
The only limit I know of is there is a limit on the number of EFX entities you can create per assembly, something like 20(not sure of exact amount), however you can create another sub assembly with 20 more if you like...
gbon
(To:gbon)
So everybody seems to agree that only limitation in number of parts.
I’ll try and tell there what is limited amount.
GB
De : Norman Luyt [
