AFX search mdl ref in the component of a main assy
YaroslavSin
Hello.
It is possible to find a reference in the component of a main assembly?
Using SEARCH_MDL_REF I'll try to find a CSYS in the skeleton part of a assembly.
I know about SEARCH_MDL_REF ASSEMBLY....
But how to search in sub-components of this assembly?
Hi @YaroslavSin ,
that will also work, but you need to take a few steps to make it happen.
  • Skeleton must be in your active assembly
  • Skeleton needs a component parameter called BUW_OBJECT_ROLE value is of your choosing, but for this example I went with "skeleton"
  • Use SEARCH_SUBCOMP_REF to find the required reference.
See structure:
See also example code:
BEGIN_ASM_DESCR
	SEARCH_MDL_REF THIS_283 CSYS CS0 CSYS_FOUND
	SEARCH_SUBCOMP_REF ASSEMBLY SKELETON CSYS CS0 CSYS_TO_ALIGN
	CONFIG_ELEM
	ASSEMBLE THIS
		CSYS CSYS_TO_ALIGN CSYS_FOUND
	END_ASSEMBLE
END_ASM_DESCR
PFA also a litte demo component that you can use (Created in Creo 7).
I hope this is what you were looking for.
Greetings Sam
Samuel Brantner
B&W Software GmbH
5 REPLIES 5
tbraxton
(To:YaroslavSin)
Have you attempted to include sub models in the search criteria?
• Look in (Available in Assembly and Drawing mode only) Select the active model. If the scope of your selection is already defined, this field is not displayed. The arrow button allows you to select the desired model from the graphics window or the Model Tree. Click the Include submodels check box to search the sub-models of the Look In model.
Involute Development, LLC
Consulting Engineers
Hi @YaroslavSin ,
what you want to do is possible.
Here the Syntax:
In the elements Modeltree show column FEAT ID to get the required number after the THIS_ statement.
Little Demo Tab file code:
BEGIN_ASM_DESCR
	CONFIG_ELEM
	ASSEMBLE THIS
	END_ASSEMBLE
END_ASM_DESCR
BEGIN_GUI_DESCR
	USER_SELECT	CSYS	CSYS_TO_ALIGN	1
END_GUI_DESCR
Hope this helps.
Greetings Sam
Samuel Brantner
B&W Software GmbH
Hello Samuel,
I can found component in the equipment assy, but no success to find skeleton part in main assy.
please clarify, THIS_# statement can search in the assembly into which the user places equipment part/assy ?
Hi @YaroslavSin ,
See structure:
BEGIN_ASM_DESCR
	CONFIG_ELEM
	ASSEMBLE THIS
	END_ASSEMBLE
END_ASM_DESCR
Greetings Sam
Samuel Brantner
B&W Software GmbH
This is was I'm looking for! Thank you, Samuel!
