Hi, can someone post the tutorial in modelling an aircraft( any aircraft). Thanks
Search Lego and collect the published bricks. Then start assembling...
http://communities.ptc.com/photoAlbums/1295
Otherwise, this is a question that is way to open to easily answer. Extrudes, Sweeps, and blends will go a long way to making something that resembles an airplane...
It might be a good idea to tell us what purpose the model will be used for.
My first reaction was that modelling a whole aircraft is a bit ambitious... I suspect that at Boeing, it takes hundreds of people several years to do this, so you might be better starting with something that has less than, say, 100 000 components. ![]()
However, I'm guessing that what you actually want is just an external representation of an aircraft.
Really, it's better to learn the basic tools that Pro/E (sorry, Creo) offers, and then you can start using those to model anything you want - in any level of detail you want.
Although Antonius' balsa plane might be a good early tutorial!
.... or the kinds with the flimsy wheels on the wire, the hook, rubber band and whirlie bird propeller for added components.
