AMD FirePro V7900 Graphics Flicker
Robert-Altman
Has anyone had an issue with a FirePro V7900 causing all the graphics
within a drawing to flicker as the mouse passes over views or
dimensions?
Everything is fine until you pause over a dimension and the popup
appears, (shown below) once that happens everything starts to flicker
until you click in an empty area of the screen.
Thanks in advance,
Hello Robert
It happened in our computers since we changed to Windows 7. The flicker happened in assembly's and drawings.
We have found 2 ways to get rid of it:
• use Aero
• disable "Show shadows under Windows" in "Performance Options"
Hope this helps
Daniel Garcia
Enviado desde mi iPhone
El 11/07/2012, a las 16:31, Robert Altman <-> escribió:
> Has anyone had an issue with a FirePro V7900 causing all the graphics within a drawing to flicker as the mouse passes over views or dimensions?
> Everything is fine until you pause over a dimension and the popup appears, (shown below) once that happens everything starts to flicker until you click in an empty area of the screen.
> <image003.png>
> Thanks in advance,
> <image002.jpg>
> Robert Altman
> Manager, CAD Engineering & Tech Support
> This e-mail and any files transmitted with it are the property of Arthrex, Inc. and/or its affiliates, are confidential, and are intended solely for the use of the individual or entity to whom this e-mail is addressed. If you are not one of the named recipient(s) or otherwise have reason to believe that you have received this message in error, please notify the sender at 239-643-5553 and delete this message immediately from your computer. Any other use, retention, dissemination forwarding, printing or copying of this e-mail is strictly prohibited. Please note that any views or opinions presented in this email are solely those of the author and do not necessarily represent those of the company. Finally, while Arthrex uses virus protection, the recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
> Attachment Links: image002.jpg (4 k) image003.png (4 k)
> Site Links: View post online View mailing list online Send new post via email Unsubscribe from this mailing list Manage your subscription
> Use of this email content is governed by the terms of service at:
