I wish that creo would automatically delete model from the drawing when its drawing sheet is deleted. We utilize multi sheet drawings which capture the entire top level assembly. We have drawings that sometimes has 200+ sheets. The annoyance occurs when a design is copied and several models are removed. One goes into the new drawing and deletes the obsolete sheets and then has to find and delete those models. I would think by now that PTC would have come up with a solution which would either automatically delete those models or prompt you to remove.
Am I the only one in this boat??
You may be able to leverage ModelCheck for this. See below from the help pages. ModelCheck can find (and delete) models that no longer drive a view in the drawing.
Y/N/E/W
Y/N/E/W
