Hello evryone,
I'm currently working on a IDX-Connection between Creo Parametric3.0 and PADSVX1.2
During the process I will have to use Creo View ECAD Validate, in order to compare, juge and validate/refuse the modification.
The problem is, every Time I want to use the ECAD Collaboration in Creo, it says I don't have access to Ecad View Validate. I receive this message if i press on Compare, or on Validation starten.
That's strange, because I have Creo View 3.1 already on my pc, and I can open Creo View ECAD, MCAD or ECAD&MCAD and use it.
Do I have to do a special configuration, or is it just a problem of Licence ?
Thanks for the responds !
Aymeric
PS: Btw, if someone is working with IDX between ECAD(PADS)-MCAD(Creo), I may have more questions ![]()
Were you successful?
What other ECAD SWs do you use and how did you achieve the integration?
Try to check if Creo View ECAD Validate and Creo View ECAD Adapters have been installed?
