Community,
When I activate any one of the models in the model tree, it will not activate, and the entire assembly remains the default gray. I am using Creo 6, and I have never encountered this type of problem before. Has anyone seen this type of problem, and is there a fix for it? Thanks in advance.
I figured out the "problem". If you go to Options>Model Display>Enable Transparency, and if you uncheck Enable Transparency, you will see what I mean. I had it unchecked, but I do not recall unchecking it. But that is it. Selecting Enable Transparency resolved the "problem". Thanks for the reply.
@ThoRig wrote:
Community,
I am not able to reproduce your problem in Creo 6.0.4.0.
