Hi, I am new to Creo. I have tried to use the Spline tool and I can't add another point OR delete an existing point upon creating a spline. I am usually forced to delete the spline and recreate it in case I want extra points or fewer points. Is there a way I can edit the spline i.e. adding another point or deleting an existing point?
I was able to figure out as per this step
Hi
You need to go to modify the spline in the sketch mode
After that you can add or delete to interpolation points or control points
Pushkar
