Adding leaders to a balloon when additional parts are added
ptc-3003679
Additional features were added to an assembly, and I need to add a 2nd leader from one balloon to the 2nd feature. I'm looking for the steps to accomplish this in the drawing mode. You can reply to my email address info@tunelink.com Thank you.
8 REPLIES 8
Try: #Table, #bom balloon, #Split and follow the instructions on the screen. br Gunnar
Thank you, Gunnar. It looks like that should be the method, however, I am getting a prompt that the item needs to be from the same table row. The table updated to the quantity of inserts, but for some reason it is not recognizing the part when I try to select it.
Try different attribute for the table
Kevin
(To:GunnarHansen)
I don't think you can add a second leader from a BOM balloon. You can add multiple leaders from standard balloons. Split allows you to split the quantity of an item between multiple balloons.
@Kevin You are right. But a workarround would be to split and then place the ballons on top of each other. (grid snap)
Kevin
(To:GunnarHansen)
In my opion there's really no need to that.
I am having the same issue for my drawing. There are 2 studs in my assembly but I cannot show in one balloon(w/qty) and 2 leaders. I cannot add 2nd leader. Anyone to help?
