Angled hole
John.Pryal
Angled hole
Hi all, i was wondering whether it is possible to create an angled hole using the hole tool feature. I want to create a hole in the top of a cylinder on a 30mm pcr angled at 15 degrees away from the cylinder centreline. Now, i have been creating such holes for years, but have always made them using the revolve cut feature, last week i was reading this forum & somebody mentioned that an angled hole can be created using the hole tool feature, but i don't see how. Can it be done? I do not want to create additional datum planes to set this up, i like to keep my models as simple as possible with the minimum amount of features. Regards John
5 REPLIES 5
I'm not sure whether it can be done 'simply' within the Hole feature... but IMHO there's nothing wrong with your current solution using Revolves. Sounds like a perfectly reasonable and robust approach, and is almost certainly how I'd do it.
It can be done with a coaxial hole. You will need to create an axis at the desired angle, and create a plane normal to the axis at the surface you want to place the hole. Use this place as the surface reference for your coaxial hole. Hope this helps. Rodney WF3
Thankyou for the replies. I realize that the hole could be created in the way you describe Rodney, but i want to avoid the creation of the extra features, ie. axis & datum plane. Regards John
John, Another approach would be to enter the coaxial hole command. After the UI for the hole pops up, then create the datums. This is called creating features "on-the-fly." The advantage of doing it this way is it buries the features within your hole command and does not add clutter to your model tree. RB 2001, WF - 2.0,3.0,4.0,5.0
