Annotate in Drawing
ttathanh
7-Bedrock
Annotate in Drawing
How to create leader note in the drawing ? Same as in this picture.
Please help me.
@ttathanh wrote:
I can create drawing symbol same as this picture but i don't know to fill black backround in circle.
Please help me.
Thank you so much!
oh yes ... setting background looks problematic. I can use Hatch/Fill command to fill circle with color. Unfortunatelly Creo does not enable me to define that note containing A letter always appears above the filled area. So this method is therefore not applicable.
You can create fixed symbol (this means you cannot set letter displayed in it) using following method.
1.] create part ... letter is cut in cylinder, x-section is defined
2.] place the part's view into temporary drawing
3.] apply Convert to Draft Entities command
4.] use resulting 2D geometry to create drawing symbol
Martin Hanák
4 REPLIES 4
you have to create drawing symbol corresponding to your request.
Martin Hanák
Please help me.
Please help me.
Thank you so much!
Martin Hanák
Thank you so much!
I try do it again.
