I need to know if anyone else has this bug and what version you are using.
When using the options editor, using "apply" when shaded w/ reflections mode is active, the reflective false floor is replaced with the room.
I finally got it to behave consistently and I even started Creo 2.0 M040 from the default install config.pro (none).
What is really annoying about it is once the room shows up, there seems to be no way to get rid of it without shutting down Creo and opening it again.
This has not always been the case. In earlier releases, I had no such issue.
please post your experience with this simple test:
Does your room become visible when you hit apply?
Please post your results with your version. If this is prevalent, I will report it to tech support.
Another similar bug is related to the "show color" option toggles for some reason.
I tried it, I did not see the room thing. M100. and hey...stop using m040!!!!
