Dec 4, 2020 1:54 PM UTC
Anyone get real fancy with part parameters and relations?
Hi guys,
Lets say i have a part file called: N12345-2000.prt
It is stored as a parameter called rel_model_name
I would like to take this parameter, and remove the first 7 characters of the name.
So I could now have this new parameter (lets call it "detail") which would just be 2000 in my parameters.
Is this possible?
Jay
BenLoosliAnswer
Dec 4, 2020 2:16 PM UTC
If it is always 7 characters before your substring, it is easy.
Detail = extract (rel_model_name,8,11)
If the number of characters varies, then you get into using the fndstr function to search the rel_model_name for your '-', which will return the start position for the extract command.
stpos = fndstr(rel_model_name,'-')
detail = extract(rel_model_name, fndstr+1,fndstr+5) assuming the detail part is always 4 characters.
If that changes, too, then there is the strlen function to get the total length.
endpos = strlen(rel_model_name)
detail = extract(rel_model_name, fndstr+1,endpos)
TomU
Dec 4, 2020 2:01 PM UTC
Edit:
Sorry, I misread your question.  Yes, as @StephenW explained, this is pretty straight forward to do.
StephenW
Dec 4, 2020 2:03 PM UTC
In the relations, use the Extract command to get what you want from the existing parameter.
I think this post has some good examples.
https://community.ptc.com/t5/Part-Modeling/EXTRACT-relations-function/m-p/577971
BenLoosli23-Emerald IIIAnswer
Dec 4, 2020 2:22 PM UTC
Yes! this is exactly what I needed.
I added a simple line:
detail = extract(rel_model_name,8,4) to get what i needed in the detail field.
Thanks for all the help guys!
Jay
Chris3
Dec 4, 2020 4:01 PM UTC
Be aware that if you try and extract more characters than are in the string (ie you have parts that don't follow the same naming scheme) it will return a Null and you will get nothing. For this reason you might want to check the length first.
