Applied Model Appearance Disappears When Modifying Object
JS_12786992
6-Contributor
I have applied an appearance to a model for carbon steel. I added the appearance by highlighting the whole part, then selecting the desired appearance. Where the issue comes into play is if you modify the part in any way, it will change the cut/intersected surfaces back to the default generic/grey appearance while it needs to be the new carbon steel appearance. Is there some sort of setting to fix this? Please see example below.
StephenW
(To:StephenW)
The way I get the part appearance set so cuts don't affect it is I pre-select the part in the model tree and then select the appearance I want it to be set to.
7 REPLIES 7
StephenW
(To:JS_12786992)
I don't see this at all when I am assigning color to the part level.
I do utilize coloring all the surfaces to help sometimes show machining processes, for my own visualization.
From what I see of your color change it's like I would anticipate an "all surfaces" selection using the right mouse button, this would "reveal" the interior color as different if cuts were made after the color selection.
StephenW
(To:StephenW)
JS_12786992
6-Contributor
(To:StephenW)
@StephenW Thank you, this is exactly what I was looking for! It appears that before when I was clicking and dragging to highlight the model it was only grabbing the exterior surfaces and not the body itself.
tbraxton
22-Sapphire I
(To:JS_12786992)
Take note that the solution from @StephenW actually selected the part model, not the body, there is a difference in the selection which becomes relevant if you have multiple bodies in a part model. Using select from list or using the context tips with preselection functionality is something that will serve you well. Check out the advanced selection tips on the Creo quick reference card if you are not familiar with them, they can save a lot of time when working in Creo.
Involute Development, LLC
Consulting Engineers
StephenW
(To:tbraxton)
Good point! I am not utilizing anything related to multibody, so it doesn't make any difference to me at this point.
JS_12786992
6-Contributor
(To:tbraxton)
@tbraxton Thank you for the explanation. We rarely use multi-body parts but they do appear sometimes, so I will keep this in mind,
BenLoosli
(To:JS_12786992)
What version of Creo are you using?
Did you select the individual surfaces or the part option by using the drop down menu in the lower right of the screen?
You need to use the body option to get the full solid to take on your new appearance.
