Arc length dimension
ptc-5279490
Pro Gurus,
Is there a way to create a strong (or even weak or reference) arc length (not chord length) dimension in sketcher?
TIA
Jim Majewski
Sorry, should have mentioned WF 4, M12.
Jim
In sketcher, select the arc, Edit, Tools, Convert to, Perimeter and it'll create a dimension for the arc length. You can also select a chain of lines, curves, etc to create a perimeter. This is in Wildfire 4.0.
Thanks!
Ted
Another method is while in sketcher: RMB,Select Dimension, pick each arc endpoint then the arc itself and place your dimension.
FYI, this is only for Creo Elements/Pro 5.0. I apologize for any confusion.
