Area calcul in familly tables
lzanettin
I need help to have the area of all instances in familly tables.
What is your method?
I have a parameter called SURFACE
And a relation : SURFACE=MP_SURF_AREA
but in the familly table, after adding the parameter SURFACE, and verifying all instances,
the aera is the same of the generic part.
My instance have different dimensions so I need each area for each instances.
Anyone have a solution?
Laurent
mbonka
(To:mbonka)
6 REPLIES 6
put your relation for AREA calculating in POST REGENERATION relations. (see attached picture). In my opinion it means that ProE will do following:
- regenerate model (change of size)
- calculate relations
mbonka
(To:mbonka)
Thank you,
it works fine,
In my family table, is it possible to put a "-" instead of the area for some instance?
we need the area only for gold plated instance.
Laurent
Yes, but it is complicated. You need a text type parameter to hold a "-" and a way to determine if the item is gold plated.
To put the text representation of a real value into a text type you need to convert the calculated area into a text type parameter. There hasn't been a function that converts real numbers to strings, but you can make one that is close.
I'm certain someone has posted it here already, but will look.
This is a conversion from a real number, area_real to a string area_string. If the item is plated, as indicated by the parameter plated_boolean, it sets the value to "-"
/*itos(int) Converts integers to strings. Here, int can be a number or an expression. Nonintegers are rounded off.
/*extract(string, position, length) Extracts pieces of strings.
/*string_length(parameter name) returns the length in characters of the string contained by parameter name
/* Create the following parameters of the type shown in the suffix. Only the fill_in_zeros_string is given an initial value
/* area_real will be set to whatever measurement result area is obtained from.
/* Parameter area_real
/* Parameter area_fraction_real
/* Parameter area_string
/* Parameter area_whole_string
/* Parameter area_fraction_string
/* Parameter decimal_places_integer
/* Parameter fill_in_zeros_string ="0000000000000000"
/* Parameter plated_boolean
/* Relations to convert real to string with given number of decimal places.
/* this is to prevent rounding of the area if itos was used directly
area_whole_string= itos(floor(area_real))
area_fraction_real = area_real - floor(area_real)
area_fraction_string = itos(area_fraction_real*10^decimal_places)
/* This replaces leading zeros; .0001 * 10000 = 1; needs to be 0001
if string_length(area_fraction_string) < decimal_places_integer
area_fraction_string = extract(fill_in_zeros_string, 1, decimal_places_integer-string_length(area_fraction_string) ) + area_fraction_string
endif
area_string = area_whole_string + "." + area_fraction_string
if plated_boolean <> True
area_string = "-"
endif
TomD.inPDX
(To:mbonka)
Never noticed that button. Great tip, Milan!
From the help files...
3.If you specified any relations as Post Regeneration, the system solves these relations after the regeneration is complete.
