Come on PTC. How many years do we need to endure the Edge Display>Erase Line and the lines do not disappear? To make matters worse the lines are erased. When I went to create a dim and attempted to use the edges, there were no edges to select, yet they are displayed. I voted up the idea for enhancing this part of the software.
I just discovered that if I turn off "Fast HLR for Drawing" The edges of the rounds that I just tried to erase (in fact, did erase) disappear. When I turn "Fast HLR for Drawing" back on (manually, found on the View tab in drawing mode), the edges re-appear!
PTC,
Is this a bug perhaps? Running Creo 3.0 M120
