I am using Creo Parametric - Release 3.0 M110
I have an issue with an assembly and the corresponding drawing. Every time that I open up the drawing and/or the assembly model, two of the components (one is a part, the other is a subassembly) are hidden in the assembly. I can unhide both of these components without difficulty, either directly in the assembly model or in the drawing by going to the model tree and selecting unhide in model. After unhiding these components I save the drawing and the assembly model (we use ECTR as our PDM system). Unfortunately, when I open the drawing and/or model again, the same two components show up as hidden again. I've tried more times than I can count to fix this problem and we've investigated everything we can think of, to no avail.
Any help would be appreciated!
after unhiding components you have to save layer status using layer tree functionality and then save the assembly.
Thank you for the reply. I'm afraid I don't quite follow. I opened the file and unhid the items. However, I can't find any option to save layer status. Are you referring to the command "Save Status" in the Visibility section of the View tab? If so, that button and the arrow menu next to it are both grayed out. I ran a search in Creo for "save layer status" and nothing popped up.
You need to switch your tree display from the Model Tree to the Layer Tree, then you can save the layer settings.
It worked. Thank you, both!
