in Creo Parametric 7.0.3.0,
Is there a function that allows me to make ALL hidden parts visible when I'm in an assembly?
Obviously, I can go through and select them individually, but this is a large assembly and it's not worth the time of day to do all that. So is there a button that does them all at once?
Easiest way is go to the layer tree, under hidden items, then under the assembly you are working on, select them all and use right mouse SHOW.
If you hid them in this session and you haven't used saved status on layers, You can right mouse in the layer area and select RESET STATUS. It will revert back to the last "saved" layer status.
