While regenrating assembly an error symbol with alphabet 'D' and cross over it occurs in status bar. What does it mean ?? How to resolve it ?
please attach a screenshot.
please find attached snap. At the bottom corner an error is displyed (highlighted in red box). No error description is visible on status bar.
I am sorry I can't help you, because I have never see "crossed D" symbol in status bar.
See:
https://community.ptc.com/t5/Creo-Modeling-Questions/TBD-next-to-green-light/m-p/255578#372552
https://www.ptc.com/en/support/article?n=CS81624
Thanks a lot.. 🙂
If you got the answer, accept appropriate reply as solution
This article reolves my query. Thanks
It means "Disconnected" and it will appear where there is some problem with the mechanism constraints.
