Assembly arrangements
CAD_user
I'm trying to insert a sub assembly of a valve In an assembly. That valve has 2 instances. In the First instance the valve is closed, in the Second is open. Do I need to have 2 different assembly files, with the correct positions, or can I have just once?
Here an example of other software, of what I'm trying to do.
https://youtu.be/FOq0f7MEvj4
2 REPLIES 2
pausob
(To:CAD_user)
You should have just one model for the valve assembly.  This valve model should allow you to position the sub-components to achieve the open / closed state.  These states can be captured using the drag bodies / snapshot tool.  The saved snapshots can be re-used in snapshots of higher level assemblies, and for visualization in the valve's drawing (if made accessible as exploded states)
StephenW
(To:CAD_user)
When you use the word "instance", everyone is going to assume you are already using a family table.
You have options:
1. Use a family table "instance" and add the dimension that controls the valve open/closed.
2. Use flexible component to control the dimension in the assembly.
3. Or as pausob described using states.
