Assembly failure
ponnarasu120
Assembly failure
 I have a big assembly which consists of many sub-assemblies and parts. If I open the main assembly some of the sub-assemblies are getting a failure, but if I open sub-assemblies first and then the main assembly it works fine.
Note: the problem is not a missing component it is a failure of sub-assemblies.
Kindly share your experience and thoughts on this issue.
Thanks in advance.
Ponnarasu Mathialagan.
9 REPLIES 9
Thanks in advance.
it looks like subassemblies are located in separated directories.
You have to add search_path options pointing to these directories into config.pro file.
Martin Hanák
ponnarasu120
(To:MartinHanak)
Hello Martin,
Thanks for your answer.
But as I mentioned the problem is not a missing component.
I assume it is about the difference in sub-assembly versions.
StephenW
23-Emerald II
(To:ponnarasu120)
Are you keeping the same sub-assemblies in different folders on your computer (or server)? This is a very bad practice and makes it impossible to know which is the latest file or even which file you are opening or have open currently.
ponnarasu120
(To:StephenW)
Hi Stephen,
I'm using the sub-assemblies which are kept in different folders only. But, not the same subassembly in different folders.
Hi Stephen,
... what search_path options are included in your config.pro file ? Can you publish them in next reply ?
Martin Hanák
ponnarasu120
(To:MartinHanak)
Hi Martin,
There are many folder directories (For ex: search_path J:\pro_tekeningen\_CAD_Standard_folder\_FASTENERS)  I have added in the config file.
I don't know which one you're asking for.
Can you give me an example?
Hi Martin,
please verify whether config.pro file contains search_path option pointing to directory, where subassembly file is located.
Martin Hanák
Search path would be something like:
G:\Engineering\ProductA
G:\Engineering\ProductB
G:\Engineering\ProductC
G:\Engineering\ProductD
G:\Engineering\ProductE
G:\Engineering\ProductF
where ProductA, ..... ProductF are the folder names. And if you have many folders, this list will be long, but needs to contain each one.
BenLoosli
23-Emerald II
(To:Dale_Rosema)
It may be easier to utilize a search.pro file and then use a single line in your config.pro pointing to the search.pro file.
1) Create a folder for your search.pro file, it can be any name and location, but preferably on a network shared drive for all users to access.
2) In config.pro enter search_path_file set to the folder your search.pro file is in with the file name.
     search_path_file x:\creo_settings\config\search.pro
3) Each line in search.pro is a folder that gets searched.
x:/creo_files\library\bolts
x:/creo_files\library\washers
x:/creo_files\library\nuts
x:/creo_files\product_a
x:/creo_files\product_b
