Assembly-level Scaling
TechSupport
Hai,
this is
Bruno.S
Sr,Application engineer
Ptc-Channel partner
Mind power engg
Its a query forwared by our Customer,
He wants to do a Part or Assembly level miniature "Scaling" the total component,by Scale ratio,through associative property,
In NX-the command name is " Scale body"
is there any option like this in Creo-2.0 Parametric
In Creo 2.0 just go to the Model Tab, select the Operations drop-down menu and select Scale Model.
Thanks Brian,,its helps me lotttttt..........
