Today when I started CoCreate PE v1.0 it took very long time - and then asked for proxy server. I have been using PE for the last year and never had any problems. The exact message was as follows: "Connection failed. For Modeling PE to automatically activate, it requires access to internet. Please check if a proxy has to be specified, and enter your company's proxy server details so that activation can proceed." Then I tried to go to www.cocreate.com and login into forums - but the login failed with a following message: "ERROR: ptc.com Account Not Authenticated Your cookies are disabled. NOTE: You must accept cookies to be able to access this site." I have the cookies enabled - but to make sure I deleted all cookies and tried to access the site again - no cigar. I checked the cookies - and yes, cookies from www.cocreate.com are saved on the comp - but the site keeps telling me that cookies are disabled. Then I tried to login into www.ptc.com (same website it appears) - and could log in without any problems. The question: Is this some kind of a problem with the authentication server ? Or any kind of a problem at www.cocreate. com ? I need to run PE - but it appears that something goes wrong, and it is not on my end I think. Does anyone have similiar problem ?
"Ken Greenwood" wrote:
I have the same proplem to the T with CoCreate PE v2.0. I hope it gets fixed soon. At least it is not just me! Thanks
