Auto Suppress Failed Components
DR_10350020
2-Explorer
Are there any configs that auto suppress failed parts on regeneration?  I am opening several parts for research that I need to regenerate and the failure diagnostics really slow me down.  Is there a way to suppress this function?
Running PTC Creo 4.0
Thanks for the help!
tbraxton
(To:DR_10350020)
I am not aware of any config option that would do this. If you are repeatedly suppressing the same features/components, then you could semi automate the process with mapkeys. The Pro/Toolkit API may have a function call for this, but I doubt it.
If you can create a search rule that will collect the components/features of interest then you can select them using the search tool and then suppress using a single suppress command.
Involute Development, LLC
Consulting Engineers
4 REPLIES 4
tbraxton
(To:DR_10350020)
tbraxton
(To:DR_10350020)
Have you tried using the suppress options in assembly mode? They may offer a quick solution if you just need to suppress items you are not interested in working with.
I have tried this, but I am looking for something more automatic that occurs as it is regenerating where creo ignores any errors that arise in the failure diagnostic.
tbraxton
(To:DR_10350020)
Automating suppression in the way you are proposing is potentially problematic in the Creo modeling paradigm so I would be surprised if this could be done without using one of the API to make custom code.
