Automated Prooduct Configurators in different CAD packeges
ptc-4931268
Hi All,
I would be keen to have a conversations with anyone interested in or has experience with automated design processes and automated parametric product
configurators.
Have we ever compared the 3 major mid range CAD packages (ProE, SW, Inventor) as yet with regards to their set of parametric tools?
There is another discussion in AD Inventor Users Group about automated design and product configurators ETO/iLogic. We used iLogic & and Excel spreadsheet and developed a fairly complex configurator. See more here..
http://www.linkedin.com/groupItem?view=&gid=130938&type=member&item=190509363&qid=250b0d6d-cde6-4abb-996c-5ffddca51ddb&trk=group_items_see_more-0-b-ttl
But we realised that due to the complexity of our models and our business objectives we have to look further and evaluate other set of tools (CAD & automated configurator options) that might do better than iLogic & excel.
So we started evaluating Creo and Solidworks with DriveWorks as alternatives in close collaboration with software vendors. (we will deploy the system globally in different locations around the world).
As far as I can see, Creo is by far is superior with its set of parametric tools (Relations, MapKeys, Pro/Program, True Top Down Design with master skeletons/multi level controllable skeletons) over the others. Creo seems to have an unrivalled set of tools due to their integrity and its all within Creo CAD. It needs some programming to drive it and to link it to our front end program, but the configurator is in Creo CAD using these tools. Even the part numbering is suggested to be generated using the ‘Relations’ tool within Creo CAD picking up the unique part properties.
Whereas Inventor needs ETO and SW needs DriveWorks Pro to cater for these functions. The parametric integrity of the built in CAD tools in Inv & SW are nowhere near to Creo’s. (Inventor has iLogic & Excel & iParts, SW has Design table & DW Express).
DriveWorks Pro for example controls each component individually, there is no parametric link (top down design kind) between the components. It is very user friendly and Excl based, not much programming is needed. In theory it does everything you need: generates new iterations of your template assy, allocates part numbers, create drawings and cost too.
The drawback might be that it uses a master ‘All in one’ assy and suppresses/deletes the unwanted components. So DW cannot generate new components and geometry. Only get rid of some that are not needed. This applies to the drawings as well, e.g. you put all dimensions on your template and it will delete the ones not needed.
It would not create painted part for you but create a phantom or normal part for paint. So the paint is on your BOM this way and can be costed.
Huhh, all this for one go... would be interested what you think...
You might ask why all this trouble, go for ETO as we have Inventor. Well we use SolidWorks too at other factories so that we have to fairly evaluate all options and come to a common parametric platform globally.
Kris
4 REPLIES 4
I just came across your post.  Are you still interested in building an Automated Parametric Product Configurator.  We have tools and skills you may be looking for.  Please contact me and let's talk.
Scott Gramman
Simplified Logic, Inc.
www.simplifiedlogic.com/
Mobile: 317-352-8596
Office:  317-644-6870
linda
(To:bgramman)
SEE OPTIONS AND CHOICES IN WINDCHILL PDM LINK, THEY ARE USED TO CONFIGURE THE PRODUCTS BY THE CHOICE OF THE OPTION. FOR EXAMPLE, CAR MAY USE 1.6 LITER OR 1.8 LITER ENGINE, BY CHOOSING 1.6 YOU HAVE A CAR WITH 1.6 LITER ENGINE INSTALLED, WHICH IS REFLECTED IN WINDCHILL PART AND CREO PART AS WELL.
NO NEED TO SHOUT LINDA! Smiley Wink (But please turn off your Caps Lock)
It's called Options and Variants in Windchill.
Hi Kris,
We at Tacton solves complex configuration problems, and design automation for all three CAD software you mentions. Long time ago since you posted this, but let me know which path you decided and how the result was.
Mathias
