Automatically Scaling a Sketch in Creo 11
APEDRONI_89
7-Bedrock
Hi, I'm a new users of Creo 11.0.2.0
I have set in my configuration (view the attachments) the option "Automatically Scaling a Sketch" but it's not work. Are there some other configuration to able or disable?
Thank you
uploaded video autoscale.mp4 shows that in my Creo 11.0.2.0 the example from youtube works well.
Suggestion:
  • remove all your config.pro files temporarily
  • start Creo
  • sketch the shape from youtube video and test autoscale functionality
Note: You can upload part containing problematic sketch. Pack part file into zip file and upload zip file.
Martin Hanák
4 REPLIES 4
please explain what you expect and what Creo does. I need to know the difference between reality and expectations.
Martin Hanák
My expectation is "https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/part_modeling/sketcher/About_Auto_Scale.html"
but if I sketch a rettangle and I change one dimension, the other dimension does not scale like in the video (see the attachment).
I try to sketch other shape but the result is the same.
Suggestion:
  • start Creo
Martin Hanák
Works as expected in Creo+ (12.1).  This only applies to the first weak dimension, in the first sketch, that is changed.  It also does not apply to an added dimension.
