BOLT DESCRIPTION IN BOM??
AntoniodeItaVen
8-Gravel
alright,
here is the thing. as long as you got the fastener extension installed you are able to insert standard bolts in your assembly, right?
Now, when creating the BOM the bolts are described as RHB###  and the nut RHN### , mmm that is ok but not at all correct?
Does anybody knows how to configure the box of the table so that it will show the details of the bolt instead of the generic name?
for instance show in the BOM 3/4 -10 UNC x 5  instead of RHB### makes more sense, isn´t it?
I appreciate any help on this
thanks in advance
Regards
7 REPLIES 7
You will need to edit the files behind intelligent fasteners to make the description and name fields match what your company needs.
bolts and nuts contain set of parameters you can use in BOM output.
MH
Martin Hanák
Martin,
loosk like my issue could be the configuration of the intelligent extension fastener. As you can see on the parameters table, I just have the generic name
I am trying to add another property but the system keeps telling my the name is invalid.
sorry it is in spanish but it gives you a good idea of what I can see in my laptop.
any other suggestion?
Thanks in advance
Antonio
I'm pretty sure that the RHB.prt comes from the PTC's Basic Library, so I'm not sure how you are dealing with the intelligent fastener extension...
Anyway, in our model, there is a parameter "DESCRIPTION" which is shown in our BOM tables:
It could be that someone in the past manually added this parameter and put in the correct value for all instances.
However, in your picture, you are showing the instance RHB239 of the generic model RHB.  I don't think you can edit the parameter table of the instance - you need to be working on the generic....
Paul Sobejko hit the target ...
rhb.prt is located in Creo3_M090\Creo 3.0\M090\Common Files\afx\parts\prolibrary\eng_part_lib\sqr_hex_bolt, its dat-file is Creo3_M090\Creo 3.0\M090\Common Files\afx\parts\screws_and_pins\screws\ANSI-ENGLISH\rhb.dat
rhb.prt does not follow rules applied to B&W parts, for example Creo3_M090\Creo 3.0\M090\Common Files\afx\parts\screws_and_pins\screws\mm\din580-c15.prt
Unfortunatelly I do not know, how to modify rhb.prt to fulfil your needs. Maybe OLIVER GRAEBNER from Intelligent Fastener Extension - IFX group will be able to help you.
MH
Martin Hanák
as Paul mentioned the rhb.prt belongs to the PTC's Basic Library.
As Martin mentioned the generic files are located in subfolders of ...afx\parts\prolibrary.
If you want to see other parameters on your model you have to change the generic file rhb.prt.
Add the columns you need to the family table.
It is also possible to use fasteners from the INCH catalog. The mechanism is a little bit different from the familiy table parts.
In this case a template exist an the *.dat file is used like a kind of family table. The template is copied, renamed and the dimensions and parameters are changed according to the dat file columns. If you want to use this mechanism you can add new columns to the dat file.
If you need more information about customizing your library visit the PTC Help Center - Tutorials:
http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/tutorials_pma/ifx_adv_intro.html
You also find additional information on the community page for Intelligent Fastener Extension - IFX
Hope this helps.
Oli
Oliver Gräbner
B&W Software GmbH
Guys,
thanks all for your answers, I did not know and I have not looked for the IFX tutorials. After all there is the way around for my BOM.
Basically I left and empty column and then I add the descrition of the bolt manually, what matters for me is that all quantities are updated and not bolts or nuts are missed.
I will try what Oliver recommends as soon as I got a break, I will post my results
thanks again
Antonio
