Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I am using Creo Parametric Release 2.0 and DatecodeM250
Need to create BOM balloon in Assembly. is there any way to create BOM balloon parametrically in assembly Model?. We have created the BOM balloon by using Session ID of Sub-Level Components. is there any better way please confirm and Guide us. Thank You.
