BOM Exporting
ptc-3088534
BOM Exporting
Does it possible to export the Bill of Material of an assembly into an Excel file instead of HTML? P.S.: My ProE version is WF2.0 Thanks to all
1 REPLY 1
Try Config option: info_output_format (set to text) then save the file as a text file. Then you can open using Excel and set columns as "Fixed Width". It's not perfect, but it gets it into something you can work with.
Chris Benner
Autodesk ® Expert Elite
