Hallo 🙂
Could you tell me, please, how I can get the Member of assembly to the BOM? Like in the BOM from gpeetersem on the picture.
What is the report symbol? Attributes are No Dup/Level and Recursive?
And is it possible to get to the BOM the file path of the part or subassembly?
Thank you in advance
Vaclav
@VV_10241385 wrote:
Thank you for your help.
But in your example should be this value for CP_P1, CP2, CP3 "PODSESTAVA", not "ASM001", because the level is 3. My idea is to fill it automatically, not to write "ASM001, ....." to the relations :-(.
Do you have another idea, please? Maybe, I explained my query incorrect.
requested repeat region functionality is not implemented. You cannot show name of component parent assembly using some "special" parameter.
The only solution is to create member_of_assembly parameter in every model and display it in repeat region using asm.mbr.member_of_assembly parameter. I case that creation of model parameters is not suitable, you can create component parameter named member_of_assembly and display it using asm.mbr.cparam.member_of_assembly parameter.
maybe you can use this "solution":
... maybe the original Member of assembly column shows model parameters defined by user in every model.
Hallo
Thank you very much. It seems, it is the best solution. And only one more parameter in the assembly ...
Have a nice day
