BOM Quantity
ptc-4632698
BOM Quantity
Hi all,
I'm having a problem with showing a quantity value in a BOM table I created. For some reason I just get a blank column even though I put in the required input (rpt.qty). Any ideas how I can get this corrected?
Many thanks.
Rob K
11 REPLIES 11
BOM?
Or attach pleace the file!
Hi Valery,
Sorry, I mean 'Bill of Materials'.
Rob
Bari
(To:ptc-4632698)
You've inputed rpt.qty or &rpt.qty?
Hi Antonio,
I input &rpt.qty. Thanks,
Rob
hi,
Have you got RPT_QTY parameter defined in your repeat region?
Under Table-->Repeat Region-->Relations-->Parameters
Dale_Rosema
(To:ptc-4632698)
Did you set up a repeat region in the table?
Thanks for the feed back guys. Yes i have entered everything as mentioned above. Thanks.
Rob
Dale_Rosema
(To:ptc-4632698)
If you are able to attach the model and drawing, someone may be able to trouble shoot it for you.
Dale
Dale_Rosema
(To:ptc-4632698)
I don't know if you were able to resolve this, but look at the threads I had pertaining to regenerating BOM's. Maybe this could solve your issue:
http://communities.ptc.com/message/185814#185814
Dale
Dale_Rosema
(To:ptc-4632698)
Robert,
We're you able to resolve this issue?
Thanks, Dale
I'm not Robert and stumbled upon this thread just now, but resolution is pretty simple: to show quantities in BOM, apart from using &rpt.qty in cell you need to change Repeat Region attributes from "Duplicates" to "No Duplicates". It is set to "Duplicates" by default and it means that instead of giving quantity of components per row every single component gets it's own row. Setting to "No Duplicates" generates single row for every component, thus adding component quantities in every row.
