BOM Table with top level assembly name
mkilic
2-Explorer
I have a BOM table exploded the all sub-components. I can reach all component's name and parameters. However I couldn't reach top level information.
Is there any way to add name or its parameter of top level assembly?
Please see the attached picture for the sample.
Thanks in advance!
I know I'm digging out an old topic but it turned out I'll need something similar to this for the ERP system we're implementing, so I was wondering if someone found out how to solve this problem. I need the file name of the assembly that the part/sub-assembly belongs to. &asm.name only gives the file name of the top level assembly which doesn't help.
I think requested functionality is not available. You have to get information manually, for example:
  • open assembly
  • use Bill of Materials command (writes .bom.* file into working directory)
  • extract information from .bom.* file
Below you can see an example of assembly structure
Assembly 00_KOMPLET contains:
     1 Sub-Assembly  01_SKRIN
     1 Sub-Assembly  02_PAKA
     1 Sub-Assembly  03_PIST
     1         Part  MH_PODSTAVA
Sub-Assembly 01_SKRIN contains:
     1         Part  I_PLYWOOD_BACK
     4         Part  J_CORNER_SUPPORT
     2         Part  I_PLYWOOD_SIDE
     3         Part  H_FRONT_BRACE
     1         Part  K_DOOR
     1         Part  MH_DNO
     1         Part  F_LEVER_FULCRUM
     2         Part  MH_PODSTAVA
Sub-Assembly 02_PAKA contains:
     1         Part  A_HANDLE
     2         Part  B_LEVER
Sub-Assembly 03_PIST contains:
     1         Part  D_COMPRESSOR_PAD
     1         Part  C_COMPRESSOR_ARM
     2         Part  E_COMPRESSOR_PAD_SUPPORT
Martin Hanák
