BOM balloons that are indexed starting at 10 - 20 - 30?
skantorski
My table reads 10 - 20 - 30 for item #'s. but my balloons are still 1 - 2 - 3.
Thanks.
2 REPLIES 2
Hi Steven,
Did you create a relation to show the repeat region index to be 10, 20, 30, etc.?  If so, then you will need to create a custom BOM balloon symbol and call out \rpt.rel.<parameter_name>\.
For example, I created a repeat region relation to show my report index as 001, 002, 003, etc.  In my relation, I defined parameter test.  In my custom symbol, I created a note and called out \rpt.rel.test\.  My BOM balloons now show 001, 002, 003, etc.
Amit
Steven,
Did you get the answer of your query in reply from Amit? If it answers, mark that as correct answer for post.
