BOM export to TXT
mike_pavese
BOM export to TXT
Hello all, we are on WF5 and I have done a search in Exploders but have not found the answer to the question of how to get the BOM from HTML to TXT or something that Excel can import with the proper information and Assembly Tree. We have even discovered that the HTML file that is exported does NOT show up correctly in Internet Explorer but only in Mozilla FireFox. I try to save from FireFox as txt but the TXT file generated is not like the HTML. Come On PTC...
Mike Pavese
4 REPLIES 4
You have to set the config.pro variable "info_output_format" to text. This will save a copy of the bam to disk which can then be opened in excel.
David W. Lawrence
Mechanical Engineer
Sigma Space Inc.
sigmaspace.com
301.552.6000
You can also change format of bom report, e.g. you can add a column to show a parameter, change the order of columns,etc.
I attach a simple example file of bom format. You should point to your bom format file (*.fmt) in config.pro using "bom_format".
Mehmet Ali Piskin
Wait a minute...did they do away with this for WF5?
(I'm using 4.0)
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
cell: (216) 990-8711
fax: (440) 266-2311
www.parker.com
Mehmet Ali Pi?kin <->
09/30/2010 08:46 AM
Please respond to
To
David Lawrence <->, mike pavese
cc
Subject
[proecad] - RE: BOM export to TXT
format file (*.fmt) in config.pro using ?bom_format?.
Mehmet Ali Piskin
Hi RObert,
That option is still there along with CSV.
Doug
