BOM table: can't open properties or enter text for certain cells
DavidSurridge
Help! I have a BOM table (one I created) which works fine except for the fact that the column I reserved for entering descriptive text, notes, etc. will only allow me to do that in the first row. I can't even open the properties window for cells in that column in any row but the first. Any suggestions? Thanks, David
This issue was resolved late yesterday afternoon. I realized that the column of cells in question might need to be outside the repeat region. This corrected the issue.
David Surridge
3 REPLIES 3
Hi
Can you give me a screenshot of your table after the following steps
1.select table
2.repeat region
3.switch syms
Regards
K.Mahanta
David Surridge
Hi
I was also expecting the same
thats why I asked to perform the above steps
It shows the repeat region area
Regards
K.Mahanta
