BOMs for different representations
GR_10314465
3-Newcomer
Good day.
We have a large assembly and want to break it up into smaller representations as would typically be the case. We have a large Bill of Materials (BOM) for the Master representation and then of course the smaller BOMs appear for the step-by-step assembly representations. Problem is that the index/item number changes within the smaller BOMs compared to the master rep BOM. Is there a way to match the master rep. BOM index/item number to the smaller BOM for the smaller representation?
Another problem is that the smaller representations cannot be ballooned from the large BOM as the large BOM is linked to the Master rep. Is there a way to allow ballooning a smaller representation ISO views from the Master rep. BOM?
2 REPLIES 2
StephenW
(To:GR_10314465)
I think you are mostly out of luck for a direct solution.
There is a product enhancement request that has a lot of work around suggestions.
https://community.ptc.com/t5/Creo-Parametric-Ideas/Allow-BOM-Ballons-from-Master-Rep-Repeat-Region-to-be-displayed/idi-p/466852
There have been lots of posts over the years about this and maybe one of them will help you get to a reasonable solution!
BG_9869104
(To:GR_10314465)
I disliked it but one way I have seen this done is each PRT/ASM has an index number parameter for its top level ASM(s). So instead of showing the auto generated index number you point to the PRT/ASM parameter in the repeat region. I hope you can see the pitfalls of this idea.
Fix Index may do what you want but I would have to test to find out if it stays fixed in the cases you want.
Is Fix Index what you want?
https://www.youtube.com/watch?v=us96vZ1RAfs
This Creo Parametric tutorial shows how to fix the index (Find Numbers) for a Bill of Materials (BOM) on a drawing. For more information, visit https://www.creowindchill.com. If you learned something from this video, please give it a thumbs up. If you like this video, please click the Subscribe ...
